| Version: | V8, 2004, XM, V8i, CONNECT | ||
| Area: | Drawing Aids | ||
| Subarea: | General |
How to open a text file with MicroStation's V8 internal viewer.
Use the TYPE key-in
For example:
TYPE c:\functionkeys.txt
This will open the text file in a separate dialog box within MicroStation rather than having to use a text editor outside.
Note: This is only for viewing the contents of the text file, not a text editor.
