| Version(s): | All | ||
| Subarea: | Geometry | ||
| Original Author: | Global Technical Support | ||
I cannot change unit system
Base unit system
While you may typically wish to work in one unit system - or even with a specific unit of force or length, it is not uncommon to use a different unit for input. STAAD.Pro allows for the input of a value in any unit in most dialog boxes. This avoids the need to manually change the unit before and after adding a command or to convert a unit to something less commonly used. A unit is entered in the most convenient format and then converted to the current units for you. This is especially useful when adding or editing loads, where the current input units cannot be changed.
To set the current input units
To change the current length and force units for inputs, use the following procedure.
