How to Change all elements to zero elevation when saving to DWG file
How to control the smoothness of curved solids when saving DWG
How to convert all of the cells in a cell library to AutoCAD (DWG) blocks
In AutoCAD elements show correct Z value but in MicroStation shows invalid Elevation
Saves to DWG and gets questions marks and asterisks for the text
Saving a DGN to DWG & the line styles are not displaying correctly
Saving to DWG, the Levels in the file do not match the original DGN file
Saving to DWG, and the elements are coming over even though the level is turned off
Shapes created by the "Place Block" command results in "3D face" elements in AutoCAD
Sheet Model displayed incorrect when DGN is converted to DWG
Unable to convert a .dgn file to a .dwg and keep one Raster image
