| Version(s): | 08.05.02.35 | ||
| Area: | Feature Based Solids Modeling | ||
| Subarea: | N\A | ||
When placing a Helix Feature the dynamic path is not circular in shape, but rather erratic in appearance.
Reduce the Tolerance value.
Reason:
The tolerance value is too high, which is not allowing the B-Spline curve, that is used to compute the path, to be circular in shape.
Lower the Tolerance value.
