| Version(s): | 08.05.02.35 | ||
| Area: | GUI | ||
| Subarea: | Dialogs | ||
How do you find out a toolbox ID number?
This is often required for the keyin:
DIALOG TOOLBOX <(><<)>toolbox_ID_number> TOGGLE
which can be used to open and close custom toolboxes.
Use the supplied MDL application 'Interface Resource Manager' which will show custom toolbox ID numbers.
This can be called via the keyin;
MDL LOAD UIMGR
or via
Utilities > MDL Applications.
