| Version(s): | All | ||
| Subarea: | Properties | ||
| Original Author: | Global Technical Support | ||
I want to add additional specification to any member / selected members and what are those means as shown in encased in red.
Select a member profile from Member list (inbuilt member library). Then select the additional specification to be assigned to it.
ST – Single Section (Default Specification)
T - Tee section cut from Beam
D - Double Profile
CM – Composite Section. It needs further additional specifications like
CT – Concrete Thickness
FC – Concrete Grade
CW – Concrete Width
CD – Density of Concrete
TC – Top Cover Plate
BC – Bottom Cover Plate
For the above two (TC and BC) Additional Specification needed as
WP – Cover Plate Width
TH - Cover Plate Thickness
TB – Top and Bottom Cover Plate. Needs further additional specification in addition to (WP & TH).
BW – Cover Plate Width
BT - Cover Plate Thickness
All are in currently selected units.
