Migrating existing custom Steel section databases to the STAAD.Pro CONNECT Edition
Product(s):STAAD.Pro
Version(s):CONNECT Edition
Environment:ALL
Area:Modeling Solutions
Subarea:Properties
Original Author:Sye Chakraborty, Bentley Technical Support Group
My company has custom steel section databases and these are mdb files. How can I get these sections into the STAAD.Pro CONNECT edition ?
The section databases in earlier versions of STAAD.Pro were MSAccess databases (mdb files) whereas in STAAD.Pro CONNECT Edition, these have been changed to SQLite databases (db3 files).
Any older mdb file that you may have, can be easily converted to the db3 format following the procedure outlined below
Click on Section Database from within the Specification ribbon menu as shown below
From within Section Database Manager, choose the options marked below and click on the Convert button ( the existing database file is assumed to be aiscsections_ml_SLS )
A command prompt window will show up as seen below showing a message that data has been successfully exported
Click on the "X" to close the command prompt window and note that a "Database converted successfully" message is also displayed at the bottom of dialog box
Click on the "X" to close out of the dialog box and close out of Section Database Manager and out of STAAD.Pro
Now manually copy the aiscsections_ml_SLS.db3 file into the following folder
“C:\Users\<user profile name>\AppData\Local\Bentley\Engineering\STAAD.Pro CONNECT Edition\Default\Sections”
Re-launch STAAD.Pro and you should now be able to access the section database
If you run into issues with accessing your database after following the procedure above, please refer to this wiki
