| Version(s): | CONNECT | ||
| Area: | Feature Based Solids Modeling | ||
| Subarea: | N\A |
Few tools present in V8i Edition are not available in Connect Edition. For example "Replace Face" or "Protrusion Feature" and some other
These tools are not deleted, but moved into "Legacy" tool box. You can recall them into this way:
Click on File > Settings > User > Tool Boxes and then choose the Legacy tool you need.
In the video attached you can see all the Legacy tools opened
Other Language Sources
| Original Author: | Mara Manconi |
