Getting Unexpected error when launching Bridge Wizard for a Steel girder bridge type.
Issue:  Getting the following error when trying to place a Steel Bridge type using Bridge Wizard
Resolution:  It is most likely the SPC Service did not get installed properly
communities.bentley.com/.../SPC.zip
