| Version(s): | ALL | ||
| Environment: | ALL | ||
| Subarea: | Loading | ||
I have defined loads in my model but STAAD.Pro is not displaying the loads graphically. What could be the reason ?
If you are using STAAD.Pro CONNECT Edition, please make sure that the following option is turned on
If you are using older versions of STAAD.Pro like the v8i, you need to turn on the following
To display values of the loads graphically, you may right click the mouse, choose Labels and then check the box Load Value as shown in the picture below. This process is the same for both CONNECT Edition and v8i.
