| Version(s): | ALL | ||
| Environment: | ALL | ||
| Subarea: | Loading | ||
| Original Author: | Abhisek Mandal, Bentley Technical Support Group | ||
How can I set my display units for load values in the STAAD.Pro CONNECT Edition?
You need to follow the steps shown in the pictures below
From the View ribbon menu within the Analytical Modeling Workflow, click on the Display Options icon and then follow the steps.
In the step 4 you can change the decimal places also.
