| Version(s): | Connect Edition | ||
| Environment: | ALL | ||
| Subarea: | Other | ||
How to measure node to node distance and dimension beams in STAAD.Pro Connect Edition ?
The options can be found at the following locations within the STAAD.Pro Connect Edition interface
Node to Node Distance :
Beam Dimensions :
