| Version(s): | ALL | ||
| Environment: | ALL | ||
| Subarea: | Other | ||
I have modeled some plates in my model but I am not able to see those. Why is that?
OR
I am unable to see certain loads in my model. Why is that?
What is visible in STAAD.Pro depends on the display settings. For example, if the plates are not visible, one should right click and choose Labels> Structure and make sure that the option marked below is unchecked.
If the geometry is not visible at all, it could be that the Hide Structure check box as shown in the picture above, is checked.
Also if certain types of loads are not visible, one should make sure that the load icons, as marked below, are turned on.
The following wiki has additional details related to visibility of loads
Loads are not displayed in the STAAD.Pro graphical user interface
