| Version(s): | 08.05.00.64 | ||
| Area: | Dimensions | ||
| Subarea: | General | ||
Dimensions are placed as separate elements even though the association box is checked on under the element dimension tool.
Use the following keyin:
KEYIN: set compatible dimension off
MicroStation V7 had a compatible setting in order to drop the dimensions upon placement. MicroStation V8 no longer has this setting in the preferences, but a key-in has been added in order to do the same.
-Turning OFF compatibility for dimensions seems to make them not
compatible.
-SET COMPATIBLE DIMENSIONS OFF seems to work in reverse.
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0112303
