| Version(s): | 08.05.02.70 | ||
| Area: | Patterning | ||
| Subarea: | General | ||
How to place an Associative Pattern and turn off the display of the bounding element?
Place the Pattern with the "Associative Region Boundary" setting toggled on - When on, patterning can be placed on a level other than the level of the patterned element. The Level of the bounding element(s) can then be turned off via Level Display/Manager.
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0108945
