| Product: | Bentley View | ||
| Version: | V8i | ||
| Area: | View | ||
| Subarea: | General |
How can I rotate a view in Bentley View V8i?
Depending on whether you have a 2D or 3D design file open in Bentley View V8i different options will display in the tool.
If you hold down the mouse button you will see the various options available to either:
Rotate View
Top View
Front View
Right View
Isometric View
Bottom View
Back View
Left View
Right-Isometric View
Here is a video show the basic operation in a 3D design file.
| Original Author: | Andrew Bell |
