| Version(s): | 08.05.01.25 | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles | ||
Annotation scale does not seem to have any affect on the dimension location stack and the stack offset value.
If the stack offset is set to 0.000 in the dimension settings, the annotation scale will not change the stack offset. However, if a value other than zero is in the field, the annotation scale will work when placing dimension in a scaled sheet.
https://communities.bentley.com/other/old_site_member_blogs/peer_blogs/b/marc_thomass_blog/posts/annotation-scale-and-the-drawing-scale-dialog
