Document Information
Document Type: FAQ
Product(s): LEAP RCPIER/Substructure
Version(s): All
Original Author: Bentley Technical Support Group -VM
QUESTION: Investigation of negative moment and reactions at interior supports for pairs of the design tandem spaced from 26ft ~ 40 ft apart combined with design lane load .where can this information be found in AASHTO spec.
ANSWER:
It’s in Article 3.6.1.3.1 under commentary (page 3-25) AASHTO code .
