RM Bridge Diagram Options specify how the diagram's results are displayed. As shown below it can be accessed within the onscreen View Options Menu directly by right-mouse-click on it.
The functions for defining the results Diagram Options are:
- Result lines appearance: Borderlines can be shown as thin or thick and the line color can be changed to the background color;
- Show result lines: As the diagrams with different normal directions usually overlap and it is possible to hide diagrams of a particular direction;
- Face appearance: Diagram faces can be represented as:
- Transparent – without any color;
- Plain colors – positive values with red color, and negative with blue color;
- Result color – color scale depending on result values is used;
- Grid pattern – additional grid lines within diagram faces are drawn;
- Show faces: Diagram of each face can connect values in different directions of the structure.
