| Version: | All | ||
| Area: | Configuration | ||
| Subarea: | User Preferences |
Did you know that the work space preference Auto Focus Tool Settings, when enabled, prevents the focus from returning to Home?
________________________________________________________________________________________________
Auto Focus Tool Settings – When enabled, this workspace preference prevents the input focus from moving automatically to the Home position when Reset is pressed. Instead the focus stays in AccuDraw which makes it a snap to position a new origin by pressing O. If you need to go home, just press ESC.
Setting off, Place smartline, data points, focus is in AccuDraw, reset and focus goes home.
Setting on, place smart line, datapoints, focus in AccuDraw, reset and focus stays in AccuDraw. Press O to position new origin and continue drafting.
| Original Author: | Dave Silver |
