| Version(s): | All | ||
| Area: | STAAD.Pro Support Solutions | ||
| Subarea: | Physical Modeling workflow | ||
| Original Author: | SANIB DAS, Bentley Technical Support Group | ||
The following video shows the process of adding Static Seismic load Cases and Response Spectrum in SSPM -
Relevant files are attached.
