Document Type: FAQ
Product(s): LEAP RCPIER/Substructure
Version(s): All
Original Author: Bentley Technical Support Group -VM
ANSWER:
Currently it is not possible to check the tensile stresses in column reinforcement using RC pier.
If there is any particular requirement from DOT then a separate hand calculation needs to be done.
