Unable to launch Steel AutoDrafter
Product(s):STAAD.Pro
Version(s):Connect Edition
Environment:ALL
Area:STAAD.Pro Support Solutions
Subarea:Steel AutoDrafter workflow
Original Author:Abhisek Mandal, Bentley Technical Support Group
I am getting the below message when trying to use Steel AutoDrafter. Please solve the issue.
Steel AutoDrafter module is included with STAAD.Pro license and can be used only if the Select entitlement is enabled in License settings as shown below.
You need to activate the Structural Select entitlements to use Steel AutoDrafter. To know more about Structural Select entitlement refer below link.
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/54321/structural-select-entitlements#:~:text=Note%3A%20Structural%20SELECT%20Entitlements%20are,STAAD.Pro%20CONNECT%20Edition%20V22.
