| Version(s): | Connect Edition | ||
| Environment: | ALL | ||
| Area: | STAAD.Pro Support Solutions | ||
| Subarea: | Steel AutoDrafter workflow | ||
The following assumptions are made in generating Material take-off.
a. Column:
Column length is calculated as per the length available from the analysis file. No deductions are made for calculating the length of the column.
b. Beam supported on the column:
Beam length is calculated as per the c/c distance between support with a deduction of 10mm on either side for the connection.
c. Beam supported on the beam:
Beam length is calculated by deducting half the thickness of the web in the case the supporting member is I-shaped. If the supporting member is RHS or SHS, half the dimension plus a gap of 10mm is deducted.
d. Elevation Bracing:
Elevation Bracing member length is calculated as drawn in the section drawings.
e. Plan Bracing:
Plan Bracing member length is calculated as drawn in the section drawings
2. Material Take-off for plan and section drawing
Material take-off is also available for selected plans and section drawings. The length of the members is calculated with the following assumptions,
a. Column:
Column length is calculated as per the floor level available ( Y-coordinates). No deductions are made for calculating the length of the column.
b. Beam Supported on the column :
Beam length is calculated by deducting half the dimension of the supporting member. In case of the beam is supported on the I-shaped column, the outermost rectangle of the column is considered for the deduction.
If the beam is released at the ends (Major moment), a drawing is generated keeping the gap of 10mm between the beam and column outer extent as a shear connection.
If the beam is not released, a drawing is generated keeping the no gap between the beam and column outer extent as a moment connection.
In both the above cases, Length is calculated as follows,
Example: beam length is 5000mm and the depth of the column on which the beam is resting on both ends is 300mm.
Beam length = 5000 – 2 x (300/2)
= 4700 mm
e. Plan Bracing:
Plan Bracing member length is calculated as drawn in the section drawings.
