| Version(s): | All | ||
| Area: |
Postprocessing workflow | ||
| Subarea: | N/A | ||
Why are my annotations for maximum bending moment or shear values not showing up in the post-processing mode?
In order to see the annotation (from Results->Annotate in the Postprocessing workflow) for a particular force or moment, the corresponding diagram must be on. For example, if one was to select maximum bending under the Beam Results page, the bending moment diagram must be on (either MX, MY and/or MZ). Also, under the Ranges tab, make sure that the "None" option is not selected. Obviously, this would not annotate anything if it were selected. As a final note, once the annotations are visible, the size and font can be changed from the Annotation tab under View-> Display Options in the main menu.
