| Version(s): | All | ||
| Area: | Post processing | ||
| Subarea: | |||
What does the below note mean in the output file
Following note message is introduced to inform that the printing of equivalent joint loads will be done in the output file only when the total number of joints is less than 1000 as the amount of output generated would not be practical for models with greater than 1000 nodes.
**NOTE: TOTAL NO. OF JOINTS IS GREATER THAN 1000 NO OUTPUT FOR APPLIED JOINT EQUIVALENT LOADS
Please refer to the revision history of STAAD.Pro CONNECT Edition build 21.00.00.42 , section A)09
To open the Revision History, please follow the steps below:
Home > Revision History for STAAD.Pro > Revision History for STAAD.Pro CONNECT Edition > What's New in STAAD.Pro CONNECT Edition, Build 21.00.00.42 ( 20 June 2017)
