PRINT LOAD DATA command
Product(s):STAAD.Pro
Version(s):ALL
Environment:ALL
Area:Postprocessing workflow
Subarea:
 How to view the load on beams coming from the slab when using the Floor Load Command.
Answer : Use the command PRINT LOAD DATA along with the PERFORM ANALYSIS command , i.e ,
PERFORM ANALYSIS PRINTLOAD DATA
 The loads generated on each member will be listed in the output file. You can view the output file from Utilities > Analysis Output.
