| Version(s): | All | ||
| Area: | Postprocessing workflow | ||
| Subarea: | N/A | ||
1. Open the start-up window of STAAD.Pro and go to the Configuration option.
2. Choose “File Options” tab and tick the “Remove Bentley Logo from Report” box. This will remove the Bentley logo from your reports
In V8i:
In CONNECT Edition:
3. Open the STAAD.Pro file. Go to the Report setup page and click on “Name and Logo” option.
4. Go to file option and choose the path where you have stored your logo. The logo should be in .bmp format.
5. Write the company name. You can orient the logo and company name by the Alignment option.
Note, Ram Elements, Connection and Ram Structural System have similar options.
For Elements or Connection go to the upper left menu - General Configuration - Print tab.
For RAM Structural System you just have to replace the logo.bmp file in the program directory with your own logo.bmp or logo.jpg file. it tends to work best when the log has roughly a 1:1 aspect ratio.
Changing / inserting the name to be printed in STAAD.Pro report / output
