Inside File\Examples\Demo Examples & FAQ user will find the Frequently Asked Questions and Solutions section for RM Bridge Enterprise. As shown in the screenshot below, user can select the T-beam model as a Demo reference entitled Ultimate Load Capacity Check - ULS. There will be the datasets to be imported and the .pdf description document about it. Ultimate Moment calculations, the relevant combinations, elements properties, reinforcement groups, cross-section geometry and material characteristics are discussed.
Additional more detailed information can be found at the FAQ example as well:
communities.bentley.com/.../concrete-structures---ultimate-capacity-check
