| Version(s): | All | ||
| Area: | Steel Design Codes | ||
| Subarea: | AISC | ||
I set my deflection limit to L/360, but the maximum deflection indicated in the summary of node displacements in PostProcessing shows a deflection of 1.5 inches. Isn't this above the limit that I set?
During steel design per the AISC ASD code, there are two types of deflection checks you can perform with STAAD. They are
LOCAL DEFLECTION is defined as the maximum deflection between the 2 ends of the beam relative to a straight line connecting the 2 ends of that member in its deflected position.
If you go to
FIle - Help - Contents - Technical Reference of STAAD Commands - TR.44 Printing Section Displacements for Members
you will find a diagram indicating this:
To obtain more information on the difference between the 2 methods of deflection checking, please go to
File > Help > Contents > Design > D. Design Codes > D1. American Codes > D1.B. American Codes - Steel Design per AISC 9th Edition > D1.B.1 Working Stress Design > D1.B.1.2 Design Parameters
At the end of the parameters table, you will see several notes. Please read Notes items 1 through 4 for the description of the two methods.
As you can see there, the default condition, which is also represented by a value of zero for the CAN parameter, is to perform the LOCAL DEFLECTION check.
Your question indicates that what you are looking for is a check of the nodal deflections. The cantilever style check STAAD offers is probably the solution for your problem. If so, specify the CAN parameter with a value of 1.
