The viewing of the cross-section table with detailed data of the finite element mesh used for calculating the integral cross-section values. The element is a quadrilateral element with possibly curved edges defined by a central node on each edge. They have a 9th node in the center point of the element and they can degenerate into a triangular element by assigning the same node number to the 3 nodes of one edge
As shown in the screenshot below, the window contains 4 areas:
- The top left is the table of cross-sections with fundamental parameters;
 - Top right is a graphic presentation of the cross-section;
 - Bottom left is the table of FE elements with assigned node points, and;
 - The bottom right is the table of coordinates of the FE node point in the cross-section coordinate system.
