| Product(s): | Sectionwizard | ||
| Version(s): | N\A | ||
| Subarea: | Properties | ||
| Original Author: | Modestas Turulis, Bentley Technical Support Group | ||
Problem Description
The changed units are not saved in the Section Wizard once it is changed in the Settings -> Preferences -> Units.
Make sure that you have full read and write privileges to the file SECTION.INI which is by default located in the folder C:\Users\<User_Name>\AppData\Local\Bentley\Engineering\STAAD.Pro CONNECT Edition\Default\SectionWizard. Actually, it would be better to have full read and write privileges to all this folder.
