Load Definition includes all possible sub functions for defining the different load impacts acting at the bridge structure:
- Combination Table: The combination table with rules for superimposing load cases and envelopesĀ for the different checks proof.
- Load Management: Automatic superposition of permanent load cases in 3 LC and 3 envelopes.
- Load Set Definition: Grouping of loads for complex analysis.
- Load Case Definition: Definition of a load case by directly specifying load definition lines or by assigning previously defined load sets.
- Traffic Lanes: Geometric positions of influence lines and surfaces.
- Load Trains: Intensity, line and axle traffic loads.
- Earthquake Load: Seismic events.
- Wind Load: Advanced wind analysis.
- Tendon Load: prestressing actions
