| Version(s): | CONNEC Edition | ||
| Area: | STAAD.Pro Support Solutions | ||
| Subarea: | Connection Design workflow | ||
| Original Author: | Modestas Turulis, Bentley Technical Support Group | ||
There are a few ways of creating RAM Connection Reports in the STAAD.Pro:
The user has to double click on the connection line in the RAM Connection Input table:
The RAM Connection window will appear. In the opened window click on Data button (to get the report of the input data) or Results button (to get the design report):
In the opened report window the user can click on the Word icon in order to export the report into MS Word:
The user can also include the RAM Connection report in the STAAD.Pro report and then print it or export into the PDF format (using a third party application). The procedure of including RAM Connection Report in STAAD.Pro is explained in the STAAD.Pro Help section Design > D. Steel Design > D. Steel Connection Design > D. Connection Design workflow > D. Using the RAM Connection mode > D. To add connection designs to your report.
