Backscatter Modulation
A method of communication between passive tags (ones that do not use batteries to broadcast a signal) and readers. RFID tags using backscatter technology reflect back to the reader radio waves from a reader, usually at the same carrier frequency. The reflected signal is modulated to transmit data.
