Battery-Assisted Tags
These are RFID tags with batteries, but they communicate using the same backscatter technique as passive tags (tags with no battery). They use the battery to run the circuitry on the microchip and sometimes an onboard sensor. They have a longer read range than a regular passive tag because all of the energy gathered from the reader can be reflected back to the reader. They are sometimes called "semi-passive RFID tags."
