| Environment: | ALL | ||
| Area: | Connection Design | ||
| Subarea: | |||
| Original Author: | Modestas Turulis, Bentley Technical Support Group | ||
I need to modify the parameters for some connections that were automatically selected by the program. Is there a way to copy that to other nodes on the job?
OR
How to modify a group of connections simultaneously in STAAD.Pro?
If you need to have the same parameters for a group of connections, here is a workflow:
1) Make sure that you have several nodes with the same connection type already designed in the RAM Connection Input table;
2) In the same table, select those connections where you want to have the same parameters. This can be done by holding CTRL button on your keyboard and selecting the required connections in the table;
3) Click the Edit button at the bottom of this table.
All modifications which are made in the Connection Pad view will be saved to all selected connections now.
