| Version(s): | All | ||
| Area: |
Postprocessing workflow | ||
| Subarea: | N/A | ||
How to see the displacement of only one particular node graphically?
1. Analyze the model and go to the Postprocessing workflow, Displacements page (by default).
2. If needed, turn on the node symbol (click Shift + K on your keyboard) and node numbers (Shift + N).
3. Go to the Results -> Annotate menu.
4. In the Ranges tab select Ranges and enter the node number(s) for which you want to see the displacement.
5. Then go to the Node tab and select Nodal Displacement which you want to see. Click Annotate.
Now the displacement of only selected node will be seen on the screen. Similarly, beam force diagram values, beam maximum displacements, beam combined stresses and support reactions can be set.
