| Version(s): | All | ||
| Area: | Postprocessing workflow | ||
| Subarea: | N/A | ||
How can I have STAAD report more than 3 places of decimal in the post processing result tables?
You need to go to View > Display Options > Choose the appropriate item and change the corresponding number of decimal places as desired > Click Apply > OK.
