| | Applies To | | |
| | Product(s): | STAAD.Pro | |
| | Version(s): | All | |
| | Environment: | N/A | |
| | Area: | Postprocessing workflow | |
| | Subarea: | N/A | |
| | Original Author: | Bentley Technical Support Group | |
When I take a picture, it prints on the top half of a 8-1/2 x 11 size page. How can I take pictures that fill the page?
There is no direct way to change the size of the picture from within STAAD.Pro. However here are a few options that you may find useful
Option 1
- Before taking a picture, please ensure that the model is
zoomed in sufficiently so that it fills up the space within the picture border as far as possible. - Take the picture and include that as part of the report using the Report Setup.
- Go to File > Print > Report > Properties and change the orientation to Landscape.
- Go to File > Report > Preview Report to check whether it looks satisfactory or not and if so, print it.
Option 2
- You may copy the picture by going to the menu option Utilities > Copy Picture. You can then paste the picture in MSWord or Excel or Paint.
- Adjust the size of the picture using the tools available within these applications and take a print from there.
