| Version(s): | V7 | ||
| Area: | Base Geometry | ||
| Subarea: | N\A | ||
After creating complex shape, element is un-editable and causes crashes in MicroStation.
Drawing a linear complex shape hits a control Z to undo the last vertex and MicroStation gives a processor exception error, sometimes an MDL abort in IGEN and a system fault 5 and Processor exception error.
The complex shape was exceeding V7 format limitation of 101 vertices.
This is not reproducible in V8 as this limitation is non existent.
Bentley's Product Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section.
For questions or comments unrelated to this article please post a new discussion in this community's forum with a link to this Wiki.
