| Version(s): | 08.05.02.35 | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles | ||
Terminator sizes are not changing when a different TextStyle is used or
Height & Width is changed.
Place Note: The Dimension Styles are loading a specific Text Style that
has pre-defined a Height and Width. Terminators in the Place Note tool
are based off these settings, when the Text Style changes the
Terminator will follow.
However when changing the Text height and width or selecting a different
Text Style in the Tool Settings dialog, this is considered and override
to the original Dimension Style. Overriding this will result in the Text
Changing but the Terminator will not follow.
To make sure the Terminators resize is based off the Text Height and Width, all changes should be made to the Dimension Styles original TextStyle.
