Real-time locating system
RTLS - A system of finding the position of assets, using active RFID tags. The tags broadcast a signal, which is received by three reader antennas. The time each signal is received is passed on to a software system that uses triangulation to calculate the location of the asset. RTLS is used to find containers in a distribution yard, and many automakers use it to track parts bins within a large factory.
