| Product(s): | MicroStation | |
| Version(s): | CONNECT Edition | |
| Environment: | N\A | |
| Area: | Sheet Composition | |
| Subarea: | Drawing Boundaries | |
How to create a boundary outline that passes through a collection of points.
In the production of planning drawings, it is sometimes necessary to define the site boundary from a collection of survey points in a design. So how do you produce a boundary by joining the outline points.
Option 1 By placing a SmartLine
- Enable AccuSnap
- Select the ' Place Smart Line ' tool and simply select the points to form the outline boundary
Option 2 Using Create Complex Chain / Shape
- Enable AccuSnap
- Select the ' Create Complex Chain ' or 'Create Complex Shape ' tool (Tool setting Method:Manual) and simply select the points in order to form the outline boundary. It may be that you can use the automatic option (Tool setting' Method:Automatic | Maximum Gap:set as appropriate) depending on dataset.
Whilst these two approaches may be OK for a simple boundary with few points it can become tedious and time consuming for larger datasets. Another approach could be to generate a surface / mesh from the points and extract the boundary.
Option 3 Using the Mesh tools
- If a 2d File - Use the File > Export > 3D (Mesh tools require a 3D file)
- Select all the Point elements using the ' Element Selection ' tool that form the required boundary.
- Use the 'Mesh From Points' tool to generate a surface mesh.
- If required modify the surface mesh removing unwanted triangles
- Extract the outline boundary of the surface mesh using the ' Extract Boundary ' tool. (Tool settings Output As:Line Strings | Extract:Boundary)
Delete the surface mesh if not required leaving the boundary
See also
Other language sources
| Original Author: | Carl Myhill | |
