Tag talks first
A means by which a reader in a passive UHF system identifies tags in the field. When tags enter the reader's field, they immediately communicate their presence by reflecting back a signal. This is useful when you want to know everything that is passing a reader, such as when items are moving quickly on a conveyor. In other cases, the reader wants to simply find specific tags in a field, in which case it wants to broadcast a signal and have only certain tags respond. (See Reader talks first.)
