| Version(s): | V8, XM, V8i | ||
| Area: | Base Geometry | ||
| Subarea: | N\A | ||
| Original Author: | Gerd Eisenacher, Bentley Technical Support Group |
While you are placing a text you notice you do not have the right settings.
Yet just nearby is another text that already has the right settings.
Wouldn't it be great if you just could pick up the attributes from the other text?
If you already use ALT+LeftMouseClick to match the basic attributes you noticed that this does match attributes like COLOR and LEVEL but does not match things like the text and pattern properties. Try the following enhancement to also MATCH TEXT and PATTERN properties-
In Workspace> Button Assignments change the "Button:" Alt+Data to the "Action:" match element fromcursor (by default it is match attributes fromcursor)
Beeing effective with the default setting you now are able to also MATCH the also the settings of your TEXT.
And not enough with this. Changing this setting you can even pick up that odd pattern setting on the fly!
p>Bentley's Product Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section.
For questions or comments unrelated to this article please post a new discussion in this community's forum with a link to this Wiki.
