| Version(s): | 08.11.07.443 | ||
| Environment: | Windows 7 32 bit,Windows 7 64 bit | ||
| Area: | UI Customization | ||
| Subarea: | Tools | ||
| Original Author: | Reginald Wallace, Bentley Technical Support Group | ||
Unable to edit or add icons to Tools Error "InvalidArgument=Value of '7' is not valid for 'SelectedIndex'. Parameter name: SelectedIndex" occurs when attempting to pick icon to add to tool using Workspace>Customize utility.
Go to location defined by MS_USERPREF variable. Check for duplicate copies of preference file customize.xml. If no duplicates exist removed the customize.xml file. This creates a new customize.xml using Workspace>Customize interface.
http://communities.bentley.com/products/microstation/w/microstation__wiki/creating-tool-icons.aspx
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0108965
