The Recalc Window Menu Options 2. Extended Settings allow users to set additional global calculation parameters for:
- Special Settings: Shear Lag and deformation, Composite Join Forces, Primary TempVar, FE results options;
- Prestressing: Cross-section Values including Tendon/Duct/Grouted areas, Elastic Compression losses, External tendon, 3D points tendon geometry
- Creep and Shrinkage: Alternative storage for Composite, factors, use internal formulas, set linear/logarithmic time stepping, aging factor, start date.
The wiki article at the link below explains how to get to the Extended Settings Window in the Recalc Window:
communities.bentley.com/.../rm-bridge-analyzer-recalculation-window
