| Area: | STAAD.Pro Webinars/Videos/Events | ||
| Subarea: | |||
| Original Author: | Surojit Ghosh |
Structural Webinars:
In 2020, Bentley Structural team has delivered several webinars on STAAD.Pro CONNECT Edition. These webinars were delivered not only to demonstrate the advanced features and new enhancements of new and updated CONNECT Edition version, but also covered several advanced structural discussions like stability analysis, seismic analysis and more.
Following are the list of all these structural events. You can go through the recorded sessions anytime by registering using the link mentioned in the table. If you have already registered, then you can directly login using the joining link sent to you earlier to your registered email ID. Note that, we monitor the sessions regularly and if you have any technical doubts, you can let us know using the Q&A console. We will get back to you via email.
| Sr. No. | Date | Event | Speaker | Registration Link |
| E1 | 20th May | Stability Analysis of Steel Structures - Part 1 | Surojit & Biswatosh | On-Demand LINK |
| E2 | 3rd June | Stability Analysis of Steel Structures - Part 2 | Surojit & Biswatosh | |
| E3 | 17th June | Working with structural instabilities and Zero Stiffness Problems | Surojit | |
| E4 | 1st July | Modelling of Physical Objects for Steel and Concrete Design | Surojit | |
| E5 | 15th July | Updates on the AISC 360 code in STAAD.Pro CONNECT Edition | Surojit | |
| E6 | 5th August | Application of Wind Loads as per ASCE 7 code | Kaushal | On-Demand LINK |
| E7 | 19th August | Modelling for Seismic Analysis in STAAD.Pro CONNECT Edition | Surojit | |
| E8 | 2nd September | Eigen Solution and Response Spectrum Method in STAAD.Pro CONNECT Edition | Kaushal | |
| E9 | 16th September | Seismic analysis based on ASCE/IBC code - Response Spectrum Method | Surojit & Dan | |
| E10 | 15th October | Seismic Analysis in STAAD.Pro CONNECT Edition based on EC8 Code - Response Spectrum Method | Surojit & Badreddine | |
| E11 | 10th December | STAAD.Pro CONNECT Edition Adoption Workshop | Surojit & Kaushal | On-Demand LINK |
| E12 | 18th May | Introduction to STAAD.Pro CONNECT Edition | Surojit | On-Demand LINK |
| E13 | 8th June | Design of Concrete Elements using Integrated Concrete Design Module | Surojit & Aswathi | |
| E14 | 29th June | Design and Drawing of Steel Member and Connection in STAAD CE | Surojit & Abhishek | |
| E15 | 17th August | Design of Foundations using Integrated Foundation Design Module | Surojit & Kaushal | On-Demand LINK |
| E16 | 22nd September | STAAD.Pro CONNECT Edition Adoption Workshop | Surojit & Kaushal | On-Demand LINK |
| E17 | 29th September | Basic of Structural Dynamics with STAAD.Pro CONNECT Edition- Part 1 | Surojit & Kaushal | |
| E18 | 6th October | Basic of Structural Dynamics with STAAD.Pro CONNECT Edition- Part 2 | Surojit & Kaushal |
Also, you can access more such videos from our YouTube channel Bentley Structural
Upcoming Events:
You can check this page to get more information of our new Coffee Corner sessions and register for the live/on-demand session.
Structural Coffee Corner
