The Recal Window 2. Extended Settings: 1. Special Settings allow the user to create additional definitions of:
- Use Shear Lag Defs for Stiffness reduct.: Shear Lag areas are ignored for bending moments of inertia reducing the CS values.
- Join Primary Forces to Composite: Primary forces of partial elements are automatically joined to composite.
- Include Primary TempVar effects: Primary stress of non-linear temperature distribution load cases.
- Ignore Shear deformation: Shear deformations due to shear forces are neglected in the analysis.
- Store leading envelope results for FE: Gives access to the Envelope with Shells Finite Elements results.
- Create results lists for area loading: Generates an auxiliary list file that contains the shell element loads.
communities.bentley.com/.../276355
